Fellas,
Will a stock long block with valve springs 60lbs injectors and a TE 62 go into the tens on a good air day and traction??? I have gone 11.24 with the te 62, 009 and 23.5 lbs of boost. Car runs with no knock, 770 o2 volts with TT 5.6 chip richened all the way and my alky spraying full blast and c16 and timing set at 27/26 . I know the turbo is good for 28lbs just don't want to lean it out. The car does have an XP pump. basically what I am asking will the 60lbs injectors and a chip reburn get me in the 10's???:biggrin:
