turbo nasty
Turbo Dojo / MNTR
- Jul 19, 2001
This was a stroker forged bottom end 109...was...
Guy gets transmission somewhat on dowel pins then bolts convertor to flywheel and then pulls the trans up to block with the case to block bolts.
Then wonders why the starter wont turn the engine over?...HMMM
Then gets a 1/2 drive socket and pull handle and a long pc of pipe puts on balancer hub bolt and is darn near swinging from the pipe on the cheater bar and the engine still wont turn.
Someone tells him to R&R the trans/conv correctly that the engine is seized due to teh trans/conv installed wrong.
He does and then starts the engine and the bottom end is knocking. So he just drives it around and jumps on the interstate after consuming "A few" and is rolling 70 plus and a rod breaks and knocks a hole in the side of the block.
Teardown revealed the thrust bearing screwed from the crank being in a bind that entailed lube circuit through bottom end issues and of course driving with it knocking like crazy.....Finished it off.. the end result. Expensive lesson
Tisk tisk tisk
Pics...
Tisk tisk tisk
Pics...
