turbodave231
Moderator
- May 24, 2001
Here are a series of quick videos on the installation of new billet main caps.
In the first video I machine the side(s) of the cap to fit the register of the block.
In the second video I chamfer the side of the cap. If you don't do this, It makes it really hard to start the cap into the register
The pictures show the caps installed after fitting. You can see the large mismatch between the new cap and the original bore. This is why the block must be Align Bored. If you tried to Align Hone the block, the mandrel would catch on the huge mismatch.......(not good)
The last video is line boring new billet caps done on a CNC Machine Center.
200 RPM and 1.0 IPM (Inch per minute)
The cut goes quick, the setup time is extensive.
This is the roughing pass A second pass was made to bring the bore to 2.6830". The last .004" was finished in the line hone. After honing the final bore size ended up at 2.6872-2.6873
DR
DR
