Fitting Billet Main Caps and Line Boring on a CNC Machine Center
turbodave231
Moderator
Here are a series of quick videos on the installation of new billet main caps.
In the first video I machine the side(s) of the cap to fit the register of the block.
In the second video I chamfer the side of the cap. If you don't do this, It makes it really hard to start the cap into the register
The pictures show the caps installed after fitting. You can see the large mismatch between the new cap and the original bore. This is why the block must be Align Bored. If you tried to Align Hone the block, the mandrel would catch on the huge mismatch.......(not good)
The last video is line boring new billet caps done on a CNC Machine Center.
200 RPM and 1.0 IPM (Inch per minute)
The cut goes quick, the setup time is extensive.
This is the roughing pass A second pass was made to bring the bore to 2.6830". The last .004" was finished in the line hone. After honing the final bore size ended up at 2.6872-2.6873
DR
That is a nice fixture y'all have! I'm going to have to get the same thing done to mine after walking the mains and fretting the mating surface.
Make sure you magnaflux the main bulkheads. If you have fretting, you might have cracks too!
I after I ran into the problems below, I always check them.
I have to bring the block to work and have it magged. That's what I did on my stock crank (magna-glow) and found it was on the way to failure (9 cracks identified).
Nice upload Dave. This is really educational. I actually didn't know what align honing the main caps meant. So this gives you a precise or more precise geometry to work with. I should start my rebuild.
The factory specification for the main bore is 2.687-2.688. Align boring and align honing always return the bore to the factory dimension (not an oversize).
I prefer to keep the bearing bore on the low side of the tolerance. On this block I ended up at 2.6872-2.6873 on all 4 bearing bores.
Keeping the bearing bores on the tight side of the tolerance improves bearing crush and heat transfer.
The bore size obviously influences bearing clearance, but it is never a good idea to use bore size to achieve your desired bearing clearance. You run the risk of spinning the bearing (bore too large) or buckling the bearing shell (bore too small, too much crush).
Curious Dave, how do you align bore and keep to factory demensions???
With new caps, they are made small and you machine them to size. With stock caps you cut material off the parting line of the cap and raise the centerline of the crank .002-.004"
Keep up the educational pictures/vids. A picture or a video is worth a thousand words.
What could cause this ? It just happened to the center caps ? Just line hone and didn't bore .?
Could be a bent crank or line a bore issue.
The fretting is pretty typical of a motor that was making some power. If it wasn't making power, then it was probably detonation leading to fretting.
