- Aug 1, 2003
if you do pull the pump stop by the pharmacy for some petroleum jelly to pack the gears
SignUp Now!Driving and lost oil pressure.
White smoke from breather, oil pressure gauge was in the middle of 0 and 25, oil light came on on the cluster.
I checked turbo line and it is not clogged... working on getting that back on after the rain stops....whats my next stuff to check??
Staranded on I55 north bound.. just south of Springfield, Illinois[/QUO
remove air inlet and check compressor side of turbo--looking for oil and in and out shaft play. You may have a bad turbo seal and burning oil--enough to drop level in pan--check up pipe!!!!--best of luck.--Lee
If you make to tour look op my friend Jason Chaney---first gen Camero---Mississippi plates
If you blew a H/G and got coolant in the oil it should read higher than .....
No.. but with the smoke from the breather... I believe the electrical gauge was working properly.Have you verified oil pressure with a mechanical gauge ??
When you replaced the head gaskets did you drop the oil pan and clean the oil pickup screen?
Damn.. . . . Never Ever ... Eeevvvvveerrr let anyone drive your car... no matter what... thats the lovely lesson I have learned.
So for all those going on the HRPT... if you see this guy (Mr Baker) ... tell him thanks for blowing up my motor.
UGHHH.... He will be on the tour with his GN with newly rebuilt motor... and the new GN he bought for his daughter.... but cant take care of what he broke on mine. Great Guy !
--- Never Ever ... Eeevvvvveerrr let anyone drive your car... no matter what... thats the lovely lesson I have learned.
Something in the lower end.... its done for. I guess im done for the season.... sigh. Maybe next year i will be able to pull it and rebuild lower end. --- Never Ever ... Eeevvvvveerrr let anyone drive your car... no matter what... thats the lovely lesson I have learned.
