captndave737
- Feb 14, 2006
I have the prewired performance ll gauges and I did have to wire in the resistor.
Factory dimmer doesn't work with this setup.
I did use the Caspers dashmate. It's true some wires don't go to it but most do.
Spent a lot of time calibrating the Speedo. Since most of us don't have a measured mile I used the highway mile markers. These are usually not exact. I drove and compared the odometer to the highway markers and it was really close for a few miles but after 10 it was .2 off so I re calibrated. Then I compared it to a GPS tracker. Now it's .15 off after 30 miles, much more accurate than any factory speedo out there but I'm going to get it exact. During the calibration the odometer window shows pulses. At the end of the mile I wrote down the pulses and then drove a while comparing it to the GPS tracker, noted the difference and then recalibrated to calculated pulses. If the odometer reads less than the actual mileage add pulses if it reads more subtract. I found I had to go to a mall parking lot so I could drive very slowly and get the pulses exactly where I wanted them.
