...I never get my winter projects done on time and the weather is too unpredictable....
Have you ever considered the Southwest?
Pretty dang nice for Gear-Heads.
SignUp Now!...I never get my winter projects done on time and the weather is too unpredictable....
Only during the winter.Have you ever considered the Southwest?
Oh Yea!........Our European friends got the skillz!........... Did you guys notice, that those headers are built with no less than 15 pieces of tubing! I've only built one set of headers in my life, and I can tell you for sure, this will be the last set I will ever build again! And if I sold them, I would want $10,000 for them. Not because there the best set ever, just to compensate me for all the mental anguish during the entire time I was doing the fab work. It's not all that bad when you don't have OCD. But when you do, it's painful. And these guys have OCD also!https://www.facebook.com/GeeMRacingRy/photos/pcb.1422563364532241/1422562907865620/?type=3&theater
Its good to see someone has the energy to innovate, just wish they were cranking out this stuff a few years ago. I searched high and low to find someone who could build my headers and paid out the ying-yang. High-5 Gee M Racing, you win the I'm not sitting on my ass and just selling parts award!! Finland looks like a cool place.
Mike
Mike
But still, even though these are just absolutely beautiful, as of now, I would have still needed to build my own set though. Because my dumb-ass had to use Champion heads and I wanted my turbos visually symmetrically located so the fab work needed to take place in the engine compartment. Can't send my ride to Finland![]()
Not bad..You DO NOT want to use that filter in that fuel line kit. I can show you flow sheets from Deatschwerks for filters the same size as the Racetronix one that shows over 1.5-2psi of backpressure from that filter.
That means just by using their kit, your fuel pump will flow LESS than a fuel line system that used a properly-sized fuel filter.
I personally run Kinsler filters because they have less than .25psi of backpressure at over 1,000lph of fuel flow. They are E85 Compatible, come with either male or female filter ends, with -8,-10,-12 sizes, and have over 74sq in of media surface area in their SMALLEST filter!! They have 25,45,75,100 micron stainless elements as well (along with paper elements for non-e85 guy).
But back to my point-get a different filter, unless you enjoy having your fuel pump flow LESS than it should!
You just gave me a good idea.That's where I mounted the one on my Dad's car too with the other bracket.
View attachment 315609 View attachment 315608
Yes, me too.Been a while. Would love to see some updates!
Nice to here your moving forward.Engine will not stay running, it starts for 2-3 seconds then stalls (XFI 2.0 purchased used), Cal and I are working through it, Cal was at the controls this morning and we gave it our best, it runs for a few seconds and stalls. We need to rule out the injectors being the cause so the used 120lb injectors I purchased from a board member are on their way to MrInjector.com for evaluation.
Before that we found the ATI balancer installed by the engine builder was installed without a 0.120" spacer, so the crank sensor was not "blinking', it was just always on (metal always sitting in the Hall sensor).
When I pulled the balancer off I saw the coolant leaking, the water pump bolts had no thread sealant, so I yanked it and installed properly.
So now I'm just waiting for the injector report and we'll go from there. Maybe a defective XFI box....?
Mike
TPS is reverse style, backwards?Injectors check out fine, engine will only run if I put my foot to the floor, when I let up it stalls. Anyone ever run across a similar problem?
Mike
Oh well, just thought I'd throw it out there.I checked the TPS, its .42V closed 4.52V WOT. i did the auto calibrate in FAST.
mIKE
