Bob Bailey ignition module
Do we need to run a ground wire from this point to the engine block?
That is where I ran the ground terminal on the TR6 harness
Mine is grounded with all the sensors by trans dipstick.
Bob please clarify.
I run LS coils but I can't see a ground to fire wall being a bad thing at that location. The LS coil harness had a ground for each bank of coils. I also use to run an additional ground from my stock coil pack to the firewall.
I just installed my TR6. Car ran like crap, kicked and bucked for half a block!! Turned around and went home. I'm using wastespark and had it turned off.:bored: Fixed it after 30 seconds of troubleshooting. I was pretty sure I knew what it was because I was in a hurry to get it installed and forgot that one little step. Just went for a test drive and it runs smoother and stronger than ever. no herky jerky with lean cruise either.
I'm guessung in a year or 2 this will be as indispensable as the MAF Translator and Bob's other products.
I'm guessung in a year or 2 this will be as indispensable as the MAF Translator and Bob's other products.[/QUOTE]
AGREED 1000%
Just installed mine. Works great! Adding two step button right now.
Okay, that two step is amazing!! Well done Bob.
jdsgnx:: are you going to be able to close your hood with those coil boots up like that? mine would not with Shanes wires
I run the same setup and wires. Those boots bend. Not quite as nice as the factory Silverado boots, but they do conform after a little while. No issues with the hoodliner thus far.
Pic
