I'm finally going to make my move this coming January/February. I've had my 87 Buick since 2004 and the time has come for me to build up the car the way I feel it should be. I am seeking advice on a few different aspects of building a high performance "109" (25526109) turbo buick engine in the near future. This will be my first time building an engine so I've enlisted the help of a good friend of mine who's been building engines since he was a sperm. I've been slowly saving money and gathering the parts needed start the build by getting all my specs ready for the machine shop since 2008. During this time I've been doing lots of web research and forum searching to gather all the information I need but I've come across a few "opinions-like-a$$holes" topics that are making me hesitant to begin the build.
Goals:
Top Priority Strength/Durability
Target Vehicle Weight: 3000lbs in race trim (87 Regal Turbo-T)
Engine: Bottom end must be capable of supporting 700hp+
Target Compression: No Higher than 8.5:1
Goal 1/4 mile ET: 9.999 second capable. Will be primarily trimmed to run a mid-low 10 seconds.
Use: 50/50 Street Strip (no block filler)
I'm not trying to break any records here but I do realize at this power level there's a potential to run into serious problems as I can really only afford to build this one time. Once started I plan document every step of the build on this forum.
Parts:
Factory 109 Block (will be thouroghly checked and magnafluxed)
Crower Billet Steel Crankshaft (Std. Stroke)
Pro-gram Engineering Billet Steel Main Caps
RJC Billet Steel Main Cap Girdle
K1 Billet Steel Connecting Rods (Std. Stroke)
Diamond Forged Aluminum Pistons (.020 over)
Comp Cams Hydraulic Roller Cam 212/212
Front Cover with integrated High Volume oil pump
(I'm open to any new Ideas that will promote strength/rigidity without compromising streetability)
Questions:
1.) Will enlarging the oil passages in mains 2 and 3 to 3/8" compromise the strength of the block? Would 5/16" be enough or am I spliting hairs?
2.) I would think the bearing oil holes must be enlarged to match each main. Is this correct or can you find bearings with the correct sized oiling holes?
3.) In my documentation for the machine shop I've set a target clearences of .0018 for main journals and .0015 for rod journals. Is this too tight for my goals?
4.) What main, rod, and cam bearings should I be going with? (Groved, Coated, Material?) Last I checked, Clevite H bearings were the way to go.)
Any additional suggestions are welcome.
Goals:
Parts:
Questions:
